![project logo](../../_images/logo-geomajas.png)
![OSGeo Project](../../_images/OSGeo_project.png)
Geomajas Quickstart¶
Geomajas itself is an application framework allowing you to build very diverse and advanced web GIS solutions.
On this OSGeo Live DVD we have included a ready-to-use Geomajas Application. This application features a map, navigation controllers, several data layers, a ribbon toolbar with GIS tools and the Layer Tree.
![An example application using the Geomajas framework](../../_images/geomajas_1024x768_screen1.png)
In this quickstart
Getting started¶
Geomajas is both available as a web demo or as a standalone application.
When using the stand-alone application, run either startup.bat on Windows, or startup.sh on Linux and Mac. You can then access the application using the following URL: http://localhost:8080/geomajas/. When you’re finished using the application, the application can be terminated by running shutdown.bat or shutdown.sh.
Using Geomajas applications¶
![The default view of the provided Geomajas application](../../_images/geomajas_screenshot.png)
Looking around¶
![The provided control for zooming within the Geomajas application](../../_images/geomajas_screenshot_zoom.png)
You can drag around the map with the mouse so the desired area is centered on your screen.
To get a closer look, you can either use the mousewheel to zoom in or use the provided zoom-buttons in the upper left of the application. You can also select an area to show by clicking the magnifier icon and selecting the desired area (via rectangular select).
Legend¶
![Layers can be consulted and toggled from the legend in the Geomajas application](../../_images/geomajas_screenshot_legend.png)
In the upper right, a toggleable legend box is provided. This legend gives you an overview of all the layers currently loaded into the application, with the option to turn them on or off. This also shows more detailed info about each layers regarding icons, colouring, …
Gathering information¶
Geomajas applications have the ability to display a variety of info within the layers. Clicking on the map will display the related info if available. By clicking the info icon in the upper left, you can toggle between basic or more detailed information.
Customizing Geomajas applications¶
If you want to use this sample application to build and customize your own Web GIS solution … please visit http://www.geomajas.org/client-gwt. The download page always features the latest and greatest sample applications, documentation, tips and tricks to roll-your-own.
What next?¶
Interested in learning more about Geomajas? The following links provide more detailed info:
