project logo
Ossim Quickstart
Open Source Software Image Map (OSSIM) is a high performance engine for remote sensing, image processing, geographical information system (GIS) tasks and photogrammetry.
  • Multi-view multiband raster satellite images with Imagelinker
  • Drape a georeferenced raster map on a 3D globe with ossimPlanet
Imagelinker
  • Start Imagelinker from its icon from the “Spatial Tools” folder on the desktop
  • Open an image file, using File ‣ Open Image ‣ /home/user/data/north_carolina/rast_geotiff/lsat7_2002_10.tif
  • Repeat the previous operation for the files : lsat7_2002_20.tif and lsat7_2002_30.tif
    ../../_images/ossim_imagelinker3.jpg
  • Another way to load all the images at once is to simply drag and drop them into the Imagelinker main window
  • To tidy up the windows, maximize the main window, then in the top menu bar go to Window ‣ Tile
  • You can keep all the satellite band views in sync by clicking Fit in one of the smaller windows, then Propagate in that same window. Try doing the same in the larger window.
  • Again in the large image window make sure the zoom button (magnifying glass) is depressed and click in middle of the big road intersection. With the closer view in the window, again click the Propagate button in the large image window to sync that view with the other band windows. In a similar way you can press the pan button (hand icon) and then click to move along the road, and then the Propagate button to align the other windows.
A more in depth tutorial covering merging bands into an RGB composite is available online.
OssimPlanet
  • Launch OssimPlanet from its icon in the “Desktop GIS” folder on the desktop
  • Select File ‣ Open Image ‣ /home/user/data/raster/meris/mosaic_MER...RGB_reduced/mosaic_ENVISAT-MER...RGB_reduced.tif to load a LANDSAT image (or simply drag and drop the image into the main window).
  • In the Layer tree panel on the left side, click on the small triangle to the left of Image Layers to expand it. Next double-click on mosaic_ENVISAT-MER_FRS.... You should now see the scene zoom to the image’s location.
Note
To turn off the daylight auto-shading, un-check File ‣ Preferences ‣ Environment ‣ Enable Ephemeris
  • Experiment with navigating the scene using the mouse. Dragging the left mouse button pans; dragging the middle mouse button rolls; and dragging the right mouse button zooms in and out.
  • If you get lost, double clicking on the Blue Marble image in the Layer tree will zoom back out to a view of the whole planet, resetting the view.
What Next?
  • We have prepared a number of tutorials demonstrating more of Ossim’s capabilities.
Copyright & Disclaimer
