Getting Started
- Click on the desktop icon in the Navigation and Maps folder
- If you have used Google Earth before you should be able to figure out this program without too much difficulty.
- In the Settings menu select full-screen mode
- Explore ...
- Click on a city name (cursor becomes a pointing hand), within the info center select the Wikipedia tab and read about the place
- In the bottom-left corner of the program window there is a button called “Map View”. Click on it.
- Select another map (e.g. ‘Precipitation (July)’)
- Explore some more ...
See the Marble homepage for more help.
