project logo
SpatiaLite Quickstart
SpatiaLite is an SQLite database engine with spatial functions added.
SQLite is a Database Management System (DBMS) which is simple, robust, easy to use and very lightweight. Each SQLite database is simply a file. You can freely copy it, compress it, and port it between Windows, Linux, MacOs etc.
This Quick Start describes how to open a spatialite database from both GUI applications and the command line. Some sample SQL queries are shown.
Using spatialite-gui
Spatialite-gui provides a visual interface for viewing and maintaining a spatialite database. You can easily see the structure of the tables and data contents using point and click functions, many of which construct common SQL queries, or craft your own SQL queries.
Let’s start by viewing a spatialite database, and looking at columns within a table:
  • Open the Spatialite GUI by selecting Geospatial->Databases->Spatialite GUI
  • Select File->Connecting an existing SQLite DB
  • Browse to the /home/user/data/spatialite directory and choose trento.sqlite.
    ../../_images/spatialite-gui-trento2.png
  • Right click on the MunicipalHallsView table and select “Show Columns”
    ../../_images/spatialite-gui-columns2.png
  • You will notice the display broken into 3 areas:
    1. The left panel displays the database hierachy, such as a list of tables, and columns within the table. Right click on elements of the left panel to select from a list of common database actions.
    2. The top right panel shows SQL for the action selected. You can enter your own customised SQL into this panel.
    3. The bottom right panel shows the results of the SQL query.
  • Right Click on the MunicipalHalls table and select “Edit table rows”. Notice the SQL query which has been created for you in the top right pane, and results in the bottom right.:
    SELECT ROWID, "PK_UID", "AREA", "PERIMETER", "COMU", "Geometry"
        FROM "MunicipalHalls"
        ORDER BY ROWID
  • Now lets try tweaking this SQL statement to get NOME and (Lat,Long) for only the NOME_PROV fields include “BRESCIA”, this time using the MunicipalHallsView. In the upper right SQL pane type:
    SELECT NOME, X(Geometry) AS Longitude, Y(Geometry) AS Latitude
         FROM "MunicipalHallsView"
         WHERE NOME_PROV LIKE "BRESCIA";
    and click the “Execute SQL” button at the right, and see the results in the bottom right pane.
    ../../_images/spatialite-gui-select1.png
Using spatialite-gis
Spatialite-gis is a simple viewer for spatialite based layers.
  • From the Desktop GIS folder on the Desktop run spatialite-gis
  • Click the “Connecting existing SQLite DB” button and connect to /home/user/data/spatialite/trento.sqlite
You should see a map of Trento Provence in Italy
  • Right click on the Highways layer and select Hide
  • Right Click on the LocalCouncilsTrento layer and select Layer Configuration->Classify and choose “Shape Area” for the column. Select 4 Classes and click on the Min and Max color patches to choose a dark and light color. Now click to see a Choropleth display of the provence areas.
  • Change border color by right click on LocalCouncils and select Layer configuration->Graphics and select a different color under Border Graphics.
  • Zoom in slightly. Right click on the PopulatedPlaces layer and select Indentify on. Now click on one of the Populated Places to see the attributes for that feature.
Running spatialite from the command line
Users needing to script or automate queries will learn the advantages of working with a spatialite database from the command line interface. In this example, we will load a shapefile, and search for schools which are near highway 42.
  • Before working from the command line, we need to open a terminal window: Applications -> Accessories -> Terminal Emulator.
  • In the terminal open a sample database with spatialite by typing:
    spatialite /home/user/data/spatialite/trento.sqlite
  • Helpful commands from the command line:
    .help
    .tables
    .quit
  • Creating a new spatialite database and loading a shapefile
    • Let’s create a new, empty spatialite database, and load two shapefiles from the north_carolina dataset:
      user@osgeo-6:~$ spatialite test.sqlite
      SpatiaLite version ..: 3.1.0-RC2      Supported Extensions:
           - 'VirtualShape'        [direct Shapefile access]
           - 'VirtualDbf'          [direct DBF access]
           - 'VirtualXL'           [direct XLS access]
           - 'VirtualText'         [direct CSV/TXT access]
           - 'VirtualNetwork'      [Dijkstra shortest path]
           - 'RTree'               [Spatial Index - R*Tree]
           - 'MbrCache'            [Spatial Index - MBR cache]
           - 'VirtualSpatialIndex' [R*Tree metahandler]
           - 'VirtualFDO'          [FDO-OGR interoperability]
           - 'SpatiaLite'          [Spatial SQL - OGC]
      PROJ.4 version ......: Rel. 4.8.0, 6 March 2012
      GEOS version ........: 3.3.3-CAPI-1.7.4
      SQLite version ......: 3.7.9
      Enter ".help" for instructions
      spatialite>
      spatialite> .loadshp data/north_carolina/shape/schools_wake schools utf-8 3358
      spatialite> .loadshp data/north_carolina/shape/roadsmajor roads utf-8 3358
    • Note the format of the .loadshp command: first the shapefile without the .shp extension, then the name of the new spatialite table, next the character encoding, and finally the EPSG code of the shapefile’s CRS.
    • Now we’ll query for schools near to highway 42.:
      spatialite> SELECT s.NAMESHORT, s.ADDRNUMBER, s.ADDRROOT
           ...> FROM schools AS s, roads AS r
           ...> WHERE r.ROAD_NAME = "NC-42" AND
           ...> ST_Distance(s.Geometry, r.Geometry) < 1000;
      FUQUAY-VARINA|6600|Johnson Pond Rd
      WILLOW SPRINGS|6800|Dwight Rowland Rd
      FUQUAY-VARINA|109|N Ennis St
      LINCOLN HEIGHTS|307|Bridge St
    • Finally, we output the query to a “comma separated values” text file “schools_rt42.txt” with the following commands:
      spatialite> .mode csv
      spatialite> .output "schools_rt42.txt"
      spatialite>.q
Things to Try
Here are some additional challenges for you to try:
  • Inspect geometries with spatialite-gui
  • Open and edit SpatiaLite layers in QGIS
What Next?
To learn more about SpatiaLite, a starting point is the SpatiaLite project page.
and be sure to visit the tutorial Spatialite cookbook
Copyright & Disclaimer
