OSGeo-Live Quickstart¶
This Quick Start describes how to start OSGeo-Live from a DVD or USB.
System Requirements¶
Your computer should have at least:
- RAM: 1 GB.
- CPU: 1 GHz i686 or compatible (Intel/AMD)
- Hard Disk:
- None required if running directly from the DVD
- 20 GB if you wish to install the operating system.
- Mouse: a 3-button mouse is useful, especially for Mac trackpad users.
Run:¶
Source an OSGeo-Live DVD, ISO available from: [Download] Put the DVD into your computer’s CD drive, then reboot your computer.
If your computer is set to boot from CD (as is often the case) you should boot up into a Lubuntu system, with Geospatial applications installed. Otherwise you’ll have to adjust the BIOS boot settings or press the boot menu button just after powering-up.
Sit back while the system boots up.
Try the many applications from the
menu.
See Also:¶
- Getting started with Lubuntu and the LXDE desktop (which is used by OSGeo-Live):
- https://help.ubuntu.com/community/Lubuntu/Documentation and http://wiki.lxde.org
- Getting started with the Ubuntu operating system:
- local eBook and extended online help
- OSGeo-Live Quickstart for Running in a Virtual Machine
- Install OSGeo-Live to Hard Disk
- Creating an OSGeo-Live Bootable USB flash drive
