project logo
GeoNetwork Quickstart
GeoNetwork is a catalog application to manage spatially referenced resources. It provides powerful metadata editing and search functions as well as an interactive web map viewer. It is currently used in numerous Spatial Data Infrastructure initiatives across the world.
Apart from how to start the catalog, this Quick Start describes: * some of the different ways you can search for spatial data * how to download and display data from the search results
Starting the catalog
After going through the installer steps, simply go to bin folder and click on start.bat (on windows) or start.sh (on linux).
Go to the home page at http://localhost:8880/geonetwork. Your first view should look like this:
../../_images/home-page8.png
Signing in and load templates
Click the sign in to connect as administrator. The default account is username admin with password admin.
../../_images/signin8.png
Once connected, the top toolbar should provide a link to the admin console and your login details.
../../_images/identified-user8.png
Go to the admin console and click on metadata and templates:
pl/quickstart/::../../images/screenshots/800x600/geonetwork//metadata-and-templates.png
Choose all standards and click load samples and then load templates in order to load examples:
pl/quickstart/::../../images/screenshots/800x600/geonetwork//templates.png
Go back to the search page to see examples:
../../_images/once-samples-are-loaded12.png
Searching information
The search form provides different ways for search:
  • a full text search box providing suggestions
../../_images/full-text8.png
  • facets which defines groups that you can easily click on to browse the content of the catalog
../../_images/facets8.png
  • spatial filtering to choose information in specific areas
../../_images/spatial-filter8.png
  • advanced search
../../_images/advanced8.png
Discovering information
Search results present main information about each resources: title, abstract, categories, status, overview and links.
../../_images/a-result8.png
Clicking the record will provide more in depth details about the resources:
  • Download and links
  • About the resource
  • Technical information
  • Metadata details
../../_images/a-record8.png
To get more information, switch the advanced view mode. To update the record, click the edit button.
From the results or the record view, you can easily add WMS layers referenced in a metadata record on the map. With the map, you can visualize your data, choose your background maps, query objects, display on a 3D globe and more ...
../../_images/map-africa-basin8.png
For more information
Continue reading the documentation: http://geonetwork-opensource.org/docs.html
