OpenLayers Quickstart¶
![project logo](../../_images/logo-OpenLayers19.png)
This Quick Start describes some basic steps required to start working with OpenLayers3: creating a basic map, adding raster and vector layers and styling features.
OpenLayers3 is a light-weight mapping library for web and mobile clients which uses modern browser technologies, such as HTML5, WebGL and CSS3.
Contents
Core Concepts¶
Before we start working with OpenLayers it helps to understand OpenLayers core concepts:
- Map
- The map is the core component of OpenLayers. For a map to render, a view, one or more layers, and a target container are needed.
- View
- The view determines how the map is rendered. It is used to set the resolution, the center location, etc. It is like a camera through which we look at the map’s content.
- Layers
- Layers can be added to the map in a stacked order, that is, lower layers are rendered before upper layers. Layers can be either raster layers (images), or vector layers (points/lines/polygons).
- Source
- Each layer has a source attached, which knows how to load the layer content. In the case of vector layers, its source read vector data using a format class (for example GeoJSON or KML) and fill the layer with a set of features.
- Features
- Features represent real world things and can be rendered using different geometries (like point, line or polygon) using a given style, which determines its look (line thinkness, fill color, etc).
A basic map¶
In this step we will create a basic map.
Create a file in say /home/user/ called basic-map.html , and copy the following into the file.
<!DOCTYPE html>
<html lang="en">
<head>
<title>Basic map</title>
<meta charset="UTF-8">
<meta name="viewport" content="width=device-width">
<!-- OpenLayers CSS -->
<link rel="stylesheet" href="http://localhost/ol3/dist/ol.css" type="text/css">
<!-- Custom styles -->
<style>
#map {
width: 100%;
height: 500px;
</style>
</head>
<body>
<h1>Basic map</h1>
<div id="map"></div>
<!-- OpenLayers JS-->
<script src="http://localhost/ol3/dist/ol-debug.js" type="text/javascript"></script>
<!-- App code -->
<script>
var map = new ol.Map({
target: 'map',
renderer: 'canvas',
layers: [
new ol.layer.Tile({
source: new ol.source.OSM()
view: new ol.View({
center: ol.proj.transform([2.1833, 41.3833], 'EPSG:4326', 'EPSG:3857'),
zoom: 6
</script>
</body>
</html>
Ex. 1: Basic code structure
Now try opening basic-map.html from a web browser. You should see the following:
![../../_images/openlayers-basic-map8.png](../../_images/openlayers-basic-map8.png)
Note:
- The code follows the best practice of loading JavaScipt code at the end of the html file.
- An OpenLayers map needs to be attached to a HTML DOM element, so we have created a
<div>
element identified by the map tag. - Maps are represented by the
ol.Map
class. We specify the DOM element to render the map into using the target property. - OpenLayers allows map rendering using three different mechanisms: Canvas, WebGL and DOM. Here we select canvas using the renderer property.
- A map shows data contained within layers, so we have created a tiled layer, represented by the
ol.layer.Tile
class, that loads content from the OpenStreetMap project, using theol.source.OSM
source class. - Finally, we set the initial position of the camera using the
ol.View
class, set the initial zoom level and center location.
Adding raster layers¶
The most used raster layers are the tiled layers, provided by the likes of
OpenStreetMap, MapQuest, Bing, etc. Tiled layers are represented by the
ol.layer.Tile
class and must use a source that knows how to load tiles from
a given provider, like ol.source.OSM
or ol.source.MapQuest
var osm = new ol.layer.Tile({
var mq = new ol.layer.Tile({
source: new ol.source.MapQuest({
layer: 'osm'
Ex. 2: Create raster layers
Layers can be added to the map in two ways:
- When constructing the
ol.Map
, using thelayers
property:
layers: [osm, mq]
Ex. 3: Adding layers on map initialization
- Adding manually with the
map.addLayer()
method:
map.addLayer(osm);
map.addLayer(mq);
Ex. 4: Adding layers manually
Adding vector layers¶
Vector layers are represented by the ol.layer.Vector
and must use a
source suitable for reading the vector format, like ol.source.GeoJSON
ol.source.KML
or ol.source.TopoJSON
var vectorLayer = new ol.layer.Vector({
source: new ol.source.GeoJSON({
url: 'url_to_geojson_file'
// Add Vector layer to map
map.addLayer(vectorLayer);
Ex. 5: Constructing a GeoJSON vector layer
![../../_images/openlayers-vector8.png](../../_images/openlayers-vector8.png)
Note, in the previous code we must change the url_to_file
to point to a
valid GeoJSON file placed in our server.
Note that Javascript security will prevents sourcing of datasets from an external URL on a different domain.
Features can also be created manually. In this case we need to create a geometry that represents the feature:
// Geometries
var point = new ol.geom.Point(
ol.proj.transform([3,50], 'EPSG:4326', 'EPSG:3857')
var circle = new ol.geom.Circle(
1000000
// Features
var pointFeature = new ol.Feature(point);
var circleFeature = new ol.Feature(circle);
// Source
var vectorSource = new ol.source.Vector({
projection: 'EPSG:4326'
vectorSource.addFeatures([pointFeature, circleFeature]);
// Vector layer
source: vectorSource
Ex. 6: Adding features by hand
Styling features¶
Features within vector layers can be styled. The style is determined by a combination of fill, stroke, text and image, which are all optional. In addition, a style can be applied to a layer, which determines the style of all contained features, or to an individual feature.
An style is represented by the ol.style.Style
class which has properties to set the fill
, stroke
, text
and image
to be applied. The next example shows the World’s administrative limits styled to use a green fill and stroke:
![../../_images/openlayers-styling8.png](../../_images/openlayers-styling8.png)
var limitsLayer = new ol.layer.Vector({
source: new ol.source.StaticVector({
url: 'data/world_limits.json',
format: new ol.format.TopoJSON(),
projection: 'EPSG:3857'
style: new ol.style.Style({
fill: new ol.style.Fill({
color: 'rgba(55, 155, 55, 0.3)'
stroke: new ol.style.Stroke({
color: 'rgba(55, 155, 55, 0.8)',
width: 1
image: new ol.style.Circle({
radius: 7,
color: 'rgba(55, 155, 55, 0.5)',
Ex. 7: Styling features
In the code, we have loaded a TopoJSON file and styled it through the style
property.
We have set a fill
and stroke
, required for lines and polygons, and an
(in this case a circle) used for point features.
Working with events¶
Most of the components, like map, layers or controls, trigger events to notify changes. For example we can be notified each time the mouse is moved over the map, when a feature is added to a vector layer, etc.
Events can be easily registered on object with the on()
method and unregistered with un()
The next code registers an event on a map instance, and is notified each time the pointer is moved. Within the callback function we obtain the pointer coordinates and print in the browser console in two different projections.
map.on('pointermove', function(event) {
var coord3857 = event.coordinate;
var coord4326 = ol.proj.transform(coord3857, 'EPSG:3857', 'EPSG:4326');
console.log(coord3857, coord4326);
Ex. 8: Printing pointer position.
What Next?¶
Sometimes the quickest way to work out how OpenLayers works is to look at examples and its source code. You can find more OpenLayers3 information here:
