This Quick Start describes how to start the OSGeo-Live DVD.
- None required if running directly from the DVD
- 5 Gig if you wish to install the operating system.
Source an OSGeo-Live DVD, ISO available from: http://download.osgeo.org/livedvd Put the DVD into your computer’s CD drive, then reboot your computer.
If your computer is set to boot from CD (as is often the case) you should boot up into an Xubuntu system, with Geospatial applications installed. Otherwise you’ll have to adjust the BIOS boot settings or press the boot menu button just after powering-up.
Press ENTER to get to next screen.
Select “live - boot the Live System”
At the login page, simply press ENTER or wait for the countdown to timeout.
Try the many applications from the “GeoSpatial” menu.
