project logo
GeoServer Quickstart
GeoServer is a java application for serving maps (and data) for other clients to draw.
  • add a vector and raster data source to GeoServer
  • apply color to map features using styling
  • test the layers in a simple web map
  • learn about clients that can display your maps
Start GeoServer
  1. Select the “Start GeoServer” icon.
  2. The application will take a few moments to start up
  3. Go to the GeoServer web page at http://localhost:8082/geoserver/web
../../_images/geoserver-login.png
First Views
When you first open the GeoServer page you will see the screen above, first you need to log in using the username admin and password geoserver. You will now see the admin page
../../_images/geoserver-welcome.png
The Layer Preview link at the bottom of the left hand menu allows you to see a preview of the layers that are loaded on the server.
../../_images/geoserver-layerpreview.png
Scroll to the bottom of the page and click on the OpenLayers link in the tiger-ny row, this will open a new window with a preview of some of the sample data.
../../_images/geoserver-preview.png
You can zoom in to the map in three ways:
  • by clicking on the zoom bar on the left, the higher you click on it the more zoomed in you will see.
  • by using the mouse scroll wheel (if you have one), scrolling up will zoom in and down will zoom out.
  • by dragging a box on the map while holding down the shift key - this will zoom in to the box selected (or as near as will fit in the screen).
  1. Experiment with this view and look at some of the other previews. Once you are happy with looking at data you can move on to adding some new data.
Loading Data
Note
You will not be able to carry out the following steps if you are running with a read only file system (such as the DVD). You will either need to install GeoServer from the DVD to your hard drive or create a USB stick based system.
In this example we are going to use the Natural Earth data set that is included on the Live-DVD (/usr/local/share/data/natural_earth/).
First we need to copy the data to the GeoServer data directory (/usr/lib/geotools-2.0.2/data_dir/data). I created a folder called naturalearth. I used a terminal window, but I expect you can do the same thing in the file manager if you prefer.
cd /usr/lib/geotools-2.0.2/data_dir/data
mkdir naturalearth
cp /usr/local/share/data/natural_earth/* naturalearth
Now we need to create a Store for our data. From the GeoServer admin page go to Stores and then click on Add new Store. You will see this page:
../../_images/geoserver-newstore.png
The New Store page
Select the Directory of spatial files, you will see the following:
../../_images/geoserver-new-vector.png
Filling in the New Store page
Type in a name for the Data Store - I used Natural Earth and fill in the URL to the data set - in this case data/naturaleath. The URL is relative to the GeoServer data directory. Press save.
../../_images/geoserver-naturalearth.png
The Natural Earth Datastore
Press publish next to one of the layers to finish up adding the data. This will take you to the Layers page:
../../_images/geoserver-publish.png
The layer publishing page
As you scroll down the page you will see that GeoServer has filled in many of the fields for you. When you reach Coordinate Reference System you will notice that under Native SRS that it says UNKNOWN [2] you will need to fill in the next box (declared SRS) to make sure GeoServer knows where the data is. For the time being trust me and type epsg:4326 in the box, if you don’t trust me then go to http://prj2epsg.org/search and paste in the string you see if you click on the link next to “UNKNOWN”. Then click on Compute from data and Compute from native bounds to fill in the Bounding Boxes. Finally hit save and you have published your first layer.
Note
If you look at this layer in the layer preview it doesn’t look very good but that is just the default style. In the next section we will look at producing a nicer style.
Styling
To style a data set into a map layer GeoServer uses an OGC standard called Styled Layer Descriptors (SLD). These are represented as XML files which describe the rules that are used to apply various symbolizers to the data.
To get started I styled the Land and Ocean datasets. You can create SLD files using a simple text editor, but sometimes a graphical editor is better. There are several options here but I like to use uDig (http://udig.refractions.net/) as it allows me to open the shapefiles directly and apply simple styles using a GUI, but also provides a simple editor to modify the XML if I need to.
Using uDig to create simple styles
Note
For more details on how to use uDig see the uDig quickstart
Once I opened uDig up and added the shapefiles (using the add data button in the top left hand corner). I dragged the 10m_land and 10m_ocean tables into the map window. uDig automatically applies a style (so you can see the data).
../../_images/geoserver-udig_startup.png
Default Styling in UDig
Now obviously an orange ocean will not work (even if I could live with the green land). So in the Layer list select the style button (it looks like an artist’s palette).
../../_images/geoserver-layer-chooser.png
The Layer list window
This will open the Style Pane - in the simple window I can easily select a nice blue for the oceans by clicking on the colored box by the fill label and choosing from the color picker it produces. I also increased the opacity of the fill to 100% to make the color look better.
../../_images/geoserver-style-pane.png
The Style Pane
Once I was done I clicked OK and uDig showed me the changes.
../../_images/geoserver-blue-ocean.png
Blue Oceans
Finally I prefer a more understated land color than green [1] so I repeated the steps above to change the color of the land layer. None of the default colors seemed right to me so I went into the define custom colors section to create one I liked.
../../_images/geoserver-custom-colour.png
Defining a nicer land color
This gives me a nice looking basic world map
../../_images/geoserver-basic-world.png
A basic word map
Adding the Style to GeoServer
Now I need to transfer these styles to GeoServer - on the style window there is an export button which allows me to save the SLD file that defines my style. Once I’ve saved the two styles I can go to the GeoServer admin page again and select Styles (at the bottom of the Data section). Then I select the Add New Style link, at the bottom of that page is a file upload box and a browse button. Clicking this allows me to hunt around on my hard drive to find the files I just saved. Once I’ve found one I want, I click the upload link (next to the browse button) and a copy of my file appears in the editor.
../../_images/geoserver-add-style.png
Adding a Style to GeoServer
Adding the Style to the Layer
Click on the Layers link in the Menu on the left of the GeoServer window. Click on the layer (e.g. 10m_land), then select the Publishing tab and change the Default Style box to the name of the style you uploaded in the previous section. Now go to the Layer Preview page to check that it looks good.
There are example style files for all of the example Natural Earth layers in /usr/local/share/geoserver.
Clients for WMS layers
A large variety of clients exist to make use of the WMS layers you are serving from GeoServer. This is a list of just some of them
Footnotes
[1]If you lived in central Pennsylvania in the summer you wouldn’t expect green either.
[2]there is a perfectly good well known text (WKT) for projections but ESRI don’t use it.
© OSGeo Foundation and LISAsoft 2011... Disclaimer
