Ushahidi Quick Start
This guide describes how to:
- Getting Ushahidi Up and Running
- Starting Ushahidi via the desktop icon or menu item opens the web
browser and brings you to the Installation page. An Ushahidi site is
pretty easy to set up
- Choose “Basic Installation”, “Let’s get started”, and it will prompt
you for a few details. The database name is “ushahidi”, database user
name is “user”, the password is also “user”. The database host is
“localhost”. Then continue. In the General setup page choose a
site name (title) for your website such as OSGeo demo and if you like
tag-line subheading as well. The email address it asks you for is used
for receiving automatic submissions which it will process and add to the
database and maps, and send automated reports from. For now set it to
something like “ushahidi@localhost.localdomain” or “ushahidi@example.org” and “Continue”.
- After that is all done it should tell you that installation was
successful and give you a link to ‘View your website’.
- To make changes in the administration area,
the login username is “admin” and the password is also “admin”.
For example in the setup page you might want to select “Settings”
(top right) and then the “Map” tab, and change the
“Map provider” to OpenStreetMaps (no API key
necessary for OSM, as it’s Open :-) ).
The setup up README page is available locally in the /var/www/ushahidi/readme.html file.
