PostGIS adds spatial capabilities to the PostgreSQL relational database system. It gives PostgreSQL the ability to store, query, and manipulate spatial data. In this note we will use ‘PostgreSQL’ when we talk about general database functions, and ‘PostGIS’ when we talk about the additional functionality that it provides.
PostgreSQL, like many database systems, works as a server in a client-server system. The client makes a request to the server and gets back a response. This is the same way that the WWW works - your browser is the client and the web server sends back the web page. With PostgreSQL the requests are in the SQL language and the response is usually a table of data from the database.
There is nothing to stop the server being on the same computer as the client, and this enables you to use PostgreSQL on a single machine. Your client connects to the server via the internal ‘loopback’ network connection, and is not visible to other computers unless you configure it to be so.
To handle spatial data you need a PostgreSQL database with PostGIS functionality. From the unix command line you can use createdb:
createdb -T template_postgis demo
Tip
Note that the command line tools provide help with –help for further information
or from the PostgreSQL command line tool psql, you can create it with SQL:
First get a list of all databases with psql and the parameter -l. Connect with a database.
psql -l
psql -d postgres
Run the SQL to create a new database:
CREATE DATABASE demo TEMPLATE=template_postgis;
To check this has worked, your database will have a lot of spatial functions and two tables: geometry_columns and spatial_ref_sys.
Tip
Note that when you are connected a database with psql you will get help with h or ?. Leave the database with q.
Now we have a spatial database we can make spatial tables. Start the PostgreSQL command-line client by entering ‘psql’ and your database name at a terminal prompt. This should connect to your database.
psql -d postgres
First we create an ordinary database table to store some city data - this table has two fields - one for a numeric ID and one for the city name:
CREATE TABLE cities ( id int4, name varchar(50) );
Next you have to add a geometry column. Conventionally this is called the_geom or geom. This tells PostGIS what kind of geometry each feature has (points, lines, polygons etc), how many dimensions (in this case two), and importantly the spatial reference system. We’ll create the geometry column using EPSG:4326 coordinates.
SELECT AddGeometryColumn ( 'cities', 'the_geom', 4326, 'POINT', 2);
Tip
Check the PostGIS table geometry_columns. YOu will find a new row with metadata for your table there.
Now we can add some data to our table. Adding the id and name values is standard SQL fare. Adding our point coordinates requires us to use a PostGIS function to convert WKT (Well Known Text) strings with a spatial reference system id.
INSERT INTO cities (id, the_geom, name) VALUES (1,ST_GeomFromText('POINT(-0.1257 51.508)',4326),'London, England');
INSERT INTO cities (id, the_geom, name) VALUES (2,ST_GeomFromText('POINT(-81.233 42.983)',4326),'London, Ontario');
INSERT INTO cities (id, the_geom, name) VALUES (3,ST_GeomFromText('POINT(27.91162491 -33.01529)',4326),'East London,SA');
As you can see this gets increasingly tedious very quickly. Luckily there are other ways of getting data into PostGIS tables that are much easier. But now we have three cities in our database, and we can work with that.
All the usual SQL operations can be applied to select data from a PostGIS table.
# SELECT * FROM CITIES;
id | name | the_geom
1 | London, England | 0101000020E6100000BBB88D06F016C0BF1B2FDD2406C14940
2 | London, Ontario | 0101000020E6100000F4FDD478E94E54C0E7FBA9F1D27D4540
3 | East London,SA | 0101000020E610000040AB064060E93B4059FAD005F58140C0
(3 rows)
If you want to have a look at your geometry in WKT format again, you can use the functions ST_AsText(the_geom) or ST_AsEwkt(the_geom). Or use ST_X(the_geom), ST_Y(the_geom) to get the coordinates
# SELECT id, ST_AsText(the_geom), ST_AsEwkt(the_geom), ST_X(the_geom), ST_Y(the_geom) FROM CITIES;
id | st_astext | st_asewkt | st_x | st_y
1 | POINT(-0.1257 51.508) | SRID=4326;POINT(-0.1257 51.508) | -0.1257 | 51.508
2 | POINT(-81.233 42.983) | SRID=4326;POINT(-81.233 42.983) | -81.233 | 42.983
3 | POINT(27.91162491 -33.01529) | SRID=4326;POINT(27.91162491 -33.01529) | 27.91162491 | -33.01529
(3 rows)
PostGIS adds many functions with spatial functionality to PostgreSQL. We’ve already seen ST_GeomFromText which converts WKT to geometry. Most of them start with ST (for spatial type) and are listed in a section of the PostGIS documentation. We’ll now use one to answer a practical question.
How far are these three Londons away from each other, in metres, assuming a spherical earth? (I’d use ST_Distance_Spheroid but my version of PostGIS doesn’t have it)
# SELECT p1.name,p2.name,ST_Distance_Sphere(p1.the_geom,p2.the_geom) from cities as p1, cities as p2 where p1.id > p2.id;
name | name | st_distance_sphere
London, Ontario | London, England | 5875766.85191657
East London,SA | London, England | 9789646.96784908
East London,SA | London, Ontario | 13892160.9525778
(3 rows)
This gives is the distance, in metres, between each pair of cities. Notice how the ‘where’ part of the line stops us getting back distances of a city to itself (which will all be zero) or the reverse distances to the ones in the table above (England to Ontario is the same distance as Ontario to London). Try it without the ‘where’ part and see what happens.
To produce a map from PostGIS data, you need a client that can get at the data. Most of the open source desktop GIS programs can do this - Quantum GIS, gvSIG, uDig for example. Now we’ll show you how to make a map from Quantum GIS.
Start Quantum GIS and choose Add PostGIS layer from the layer menu. Because you haven’t interacted with PostGIS from QGIS before, you’ll get an empty set of PostGIS connections.
Hit ‘new’ and enter the parameters for the connection. We’ll use the Natural Earth database provided on the DVD system. There’s no username or password because the security is set up to allow you access.
Hit the Test Connect button, and if all is well you’ll get a friendly message. Hit OK and your connection info is saved under the name in the drop-down box. Now you can hit Connect and get a list of the spatial tables in the database:
Choose the lakes and hit Add, and it should be loaded into QGIS:
You should now see a map of the lakes. QGIS doesn’t know they are lakes, so might not colour them blue for you. Use the QGIS documentation to work out how to change this! Zoom in to a famous group of lakes in Canada.
Most of the OSgeo desktop tools have functions for importing spatial data in files, such as shapefiles, into PostGIS databases. Again we’ll use QGIS to show this.
Importing shapefiles to QGIS can be done via a handy PostGIS Manager plugin. To set it up, go to the Plugins menu, select Manage Plugins and then find the PostGIS Manager. Check the box and OK it. Now on the Plugin menu you should have a PostGIS Manager entry which gives you an option to start the manager.
It will then use your previously defined settings to connect to the Natural Earth database. Leave the password blank if it asks. You’ll see the main manager window.
You can use the other tabs in the right-side panel to check the attributes of the layer and even get a basic map with zoom and pan capabilities. Here I’ve selected the the populated places layer and zoomed in on a little island I know:
Now to read in a shapefile. From the Data menu choose the Load data from shapefile option. All you need to do here is browse to the world shapefile in the data directory of the osgearth folder, and give the table a name. Leave everything else. Hit Load.
The shapefile should be imported into PostGIS with no errors.
Now get back to the main QGIS window and load the world data into the map using the ‘Add PostGIS Layer’ option. With a bit of rearranging of the layers and some colouring, you should be able to get something like this:
You can use the graphical database client pgAdmin III to run you SQLs and handle your data. pgAdmin III also provides a plugin for shape import. This client provides a comfortable way to manage your data.
Here are some additional challenges for you to try:
This is only the first step on the road to using PostGIS. There is a lot more functionality you can try.
PostGIS Project home
http://postgis.org
PostGIS Documentation
