uDig (User Friendly Internet Desktop GIS), is a GIS Desktop client for editing and viewing GeoSpatial data.
- load a map layers from a shapefile and Web Map Service (WMS)
- use the standard map tools
- apply colour to map features using styling
If you have any difficulties, or are running uDig please review the Running uDig reference page.
You can return to the Welcome view at any time by selecting the Help > Welcome from the menu bar.
The Workbench window offers multiple Editors (each showing a Map) and supporting Views (offering information about the current Map).
Shown above is a typical uDig session with the Map editor, Projects view, Layers view and Catalog view labelled . These views will be described further as we demonstrate their use.
To start out with we are going to load some of the sample data included on the DVD.
Note
One of the most common questions asked when uDig is considered for an organization is how much memory the application uses. Unlike most GIS applications uDig can get by with a fixed amount of memory. The above shapefile is not loaded into memory, we have a policy of keeping data on disk and drawing data like this shapefile onto the screen as needed.
Tip
You can also drag and drop shapefiles directly into the uDig application!
You can control where in the world the Map Editor is looking by using the navigation tools in the tool bar along the top of the screen.
Tip
Most tools allow you to Pan by holding the center button and control the scale using the scroll wheel.
One of the reasons to use an application like uDig is to access all the great free geospatial information available on the web. This section covers the use of Web Map Servers which make available layers of information that you can mix into your own maps.
Tip
You can also connect to Web Map Servers using the Add Data Wizard for Drag and Drop.
Tip: You can switch between the zoom and info tools by pressing Z and I on the keyboard.
Select the project > countries, you can double click to open this Map, or Right Click and choose Open Map
Select the countries layer in the Layer view
Open up the Style Editor by right clicking on countries layer and choosing Change Style
We are going to change a few things about how countries are displayed
Press Apply to see what this looks like on your Map, the Layer view will also be updated to reflect the current style
When you are happy with the result you can press Close to dismiss the dialog
Some files include style settings, Select Layer ‣ Add from the menu bar
Select Files from the list of data sources and press Next
Using the file chooser open up timezone.shp and press Open
It is a bit hard to see what is going on with the clouds.jpg layer providing so much details. Select Map ‣ Mylar from the menu bar to focus on the selected layer
Using the Layer view select timezone, countries and clouds.jpg in turn to see the effect
Here are some additional challenges for you to try:
This is only the first step on the road to using uDig. There is a lot more great material (and ability) left for your to discover in our walkthroughs.
Walkthrough 1
Try out the use of PostGIS, extract data from a Web Feature Server and explore the use of Themes with our powerful Color Brewer technology.
/usr/data/udig/udig-docs/uDigWalkthrough 1.pdf
Walkthrough 2 - Learn how to create shapefiles and use the Edit tools to manipulate feature data, covers the installation of GeoServer and editing with a Web Feature Server.
Available on http://udig.refractions.net/
