We have installed many common languages. In order to switch the system you will need to:
- Log out
- On the user selection screen pick a user.
- In the bottom panel you will now see a menu to select a different language.
- Select another language and enter the password and continue the login as usual.
- Repeat the process if wish to change languages again.
The system menus and many of the applications will now appear in the language choosen. If a specific program continues to display in english there is no translation available currently, please consider volunteering to write a translation. Contact the program of interest directly for more information.
For additional languages see Application → System → Language Support (Requires an internet connection).
International keyboard support is installed, but you will need to configure the system for your specific keyboard.
