Install OSGeoLive to Hard Disk
OSGeoLive can be installed onto your hard disk, the same way an Ubuntu distribution is installed.
This process can also be run inside a Virtual Machine to create a permanent OSGeoLive Virtual Machine from a DVD or ISO image.
System Requirements
  • 20 GB of spare Hard Disk Space
Install OSGeoLive
../../_images/osgeolive_install_start.png
Select Install RELEASE
../../_images/osgeolive_install_password.png
Enter password=”user”
../../_images/osgeolive_install1_language.png
Select language
../../_images/osgeolive_install2_timezone.png
Select timezone
../../_images/osgeolive_install3_keyboard.png
Select keyboard
../../_images/osgeolive_install4_disk.png
Specify which disk to want to install on. (Beware, this may delete an existing installed partition).
../../_images/osgeolive_install5_username.png
Defaults for settings are:
  • Name = “user”
  • username = “user”
  • password = “user”
  • computer name = “osgeolive”
  • Log In automatically
../../_images/osgeolive_install7_check.png
Select Install
Go and get a cup of coffee while installation is in progress.
That is it.
Tip
Installation Tips In case you are installing using a username other than “user”, tomcat applications require to have permission to service command as described in https://trac.osgeo.org/osgeo/ticket/1153
