QGIS Server Quickstart¶
QGIS Server provides a web map service (WMS) based on libraries from the QGIS desktop application.
- update an existing QGIS project and render it with QGIS Server
- create a new QGIS project and open the WMS directly in a browser
Start GeoExt viewer¶
OSGeoLive contains an example of web map viewer based on the GeoExt Javascript framework and using QGIS Server for rendering the map.
- Click . You should see a browser window with a web map viewer showing a world map.
Alternatively, you can access the application using a browser through http://localhost/qgis_server
Edit QGIS project¶
We will now change the map styling using QGIS.
- Click .
- Choose from the menu bar.
- Select
QGIS-NaturalEarth-Example.qgs
and press Open.- You should see the same world map rendered by QGIS. We will now change river styling and look at the result in the web map viewer.
- Double click
ne_10m_rivers_lake_centerlines
in the Layers tree. - Change the color in Outline Options to a different blue tone.
- Press OK. Rivers are now rendered in a new color.
- Save the project with .
- Reopen the web browser.
- Zoom in. You will now see rivers rendered in the same new color.
Create a new QGIS project¶
- Reopen QGIS.
- Choose .
- Click .
- Browse to dataset
/home/user/data/natural_earth2/ne_10m_admin_0_countries.shp
. - Press Open. You should see all world countries.
- Use file name
/home/user/world.qgs
and press Save. - Open the WMS URL. You should see all world countries, this time rendered by QGIS Server.
What next?¶
To learn more about QGIS Server, a good starting point is the QGIS User Guide.
Quick start for Server Installation on Debian/Ubuntu:
- apt-get install qgis-mapserver libapache2-mod-fcgid
- -> http://localhost/cgi-bin/qgis_mapserv.fcgi
- QGIS Web Client:
